I posted a message back on 12th January regarding a dodgy boiler installation and received from really useful advice.
Basically, the story is that about one year ago I had my old Myson combination boiler replaced with a new Potterton Performa 24 and the installing engineer, using the existing pipework, connected it in the same way as the Myson.
The problem was that the Myson, a Midas Sfi had the central heating return on the left and the central heating flow on the right whereas on the new Potterton Performa 24 they are the other way round.
The engineer, for some reason, did not take this into consideration and, because of this, has connected them the wrong way round, which explains all the problems we have been experiecing with radiators and pipes 'whirring' and then banging.
Because we do not have a roomstat or a radiator with lockshields fitted the advice I was given via this Forum was:-
The installation did not conform to Building Regs (2002).
To put things right the following works needed to be carried out:-
A/ alter the pipework under the boiler so trv are on the flow
B/ remove a trv and replace with lockshield
C/ fit a rf roomstat in the coolest part of the house[hallway]and make the hall radiator a bypass with a pair of lockshields[interlock]
I pointed this out to the Firm that installed it and yesterday they came round to put things right.
To my complete surprise, all they did was to change the existing TRVs so that they now are fixed horizontal to the vertical 'return' pipe coming up through the floorboards, instead of vertical, as they were.
As before, all seven radiators (three floors), are fitted with TRVs.
The senior of the two engineers that came told me this would solve all our problems.
He also told me:-
"The makers of this particular boiler recommend that the TRVs are fitted to the return as it is cooler than the flow so the engineer who installed it did so correctly.
The Building Regulations are purely 'best practice guidelines' and not in any way compulsory so we do not need fit a roomstat or lockshields. The only time that you may be asked about this is if you were selling the property and if this was the case you will just have to make sure that any prospective buyer was made fully aware of this.
The boiler has an internal bypass so there is no need for lockshields to be fitted and a roomstat is also not needed as the TRVs will do the same job"
I was a little suspicious of this and have contacted Baxi Potterton, the manufacturers of the new boiler, by E-mail and, although very reluctant to give any information, in writing, suggesting instead that I telephone their Customer Helpline, they did say the following:-
"Following your enquiry regarding the Potterton Performa, no such
recommendation from ourselves, usually TRV's are on flow. If you require
any further information please don't hesitate to contact the technical help
line.
I would be very grateful for any further advice on this one.
He also told me:-
line.
