I had some electrical and plumbing work done in my kitchen last week and I had a few problems. Just wondering if anyone can give me some advice.
The company now want paying but I'm holding off for reasons you'll see in a minute.
Firstly, whilst finishing off the work 3 days late, one of the workers was wiring in a plug socket. He'd turned off the power at the fuse board to do this and when he turned the power back on, the fuse for the lower ring main blew - big black marks on the fuse board above and below the fuse. I pointed this out to him and he took out the fuse, stripped some old wire from an old socket and wrapped it around the fuse. When he plugged it back in it appeared to do the trick although I was a bit concerned about this.
The following day I had a friend of the family coming round to check on the new boiler (qualified plumber & electrician, corgi registered etc...) which he'd put in two weeks previously. Quite literally as he pulled up in his car, the fuse in the fuse board blew again. He came in and saw straight away that they hadn't used 30 amp fuse to re-wire it, but several thin strands instead. He proceeded to check over the rest of the electrical work they'd done. This is what he found:
- Incorrect wiring used to re-wire fuse in the fuse board.
- None of the water or gas pipework (copper) had been bonded.
- No earth sleeving on any of the earth cables in any of the plug sockets or cooker power socket.
- The gas pipework had been extended by several feet (above floor level) and no clips attached to the wall were used to support it.
- No rubber grommet protecting the wires from the metal case of the cooker power outlet.
- Electrical wiring had been connected under the floor and simply wrapped in tape.
I was told that they have broken electrical regulations with this work but I'm unsure as to which items he was specifically talking about, so if anyone here could point this out to me I'd be grateful. I want to know whether I can get money taken off of the bill because of having to have their mistakes fixed; I'd rather not have to pay twice for the work.
Thanks.
Thanks.
