Hi all.
Today, I went to my brother's house to replace his kitchen tap, had to move the washing machine out of way to undo tap back nut, after I finish the tap, after a good tea break and a telly later, I noticed the socket that is behind the wash. machine is a double socket with spur to w/m and there was 2 plugs in, we had no idea where this go to so I switched off both:
one goes to a outside light
one goes to a other double socket supplying a microwave oven in other side of kitchen
Also my brother ask me if it would be possible to remove a gas hob, oven and replace with a freestanding cooker, I say yeah, I can but not the hob, so I start by looking for a cooker point but it disappered but on old CU there is a 6mm cable going somewhere, and as I remember when I installed a new part wet room shower, after replacing flooring, there is 6mm cable going to a wall and I work out it must had drop down to below wall unit and I think it must had a choc block changing from 6mm to 2.5mm to the oven and sparking unit for hob. It might be buried in wall.
So what I am going to do is to remove wall tiles to find the end of 6mm and remove the 2.5mm to oven and replace it with a new cooker switch with a socket ( which will be use for microwave ) and new metal box as well and run new 6mm to the cooker via a connector box.
Then, on the socket, I will remove the socket that supplying the microwave and it cable, plug etc, then put the outside light on the lighting system then remove the double socket and replace it with a fuse spur to a single socket for the washing machine.
Do you agreed with above? I will supply some photos in a few months time ( when it warmer )
Also I found the CU has only got four way rewireable fuse for lighting, immerison, cooker and ring main. I have replace all the fuse with MCB. But I am confused as to why there was only one fuse for ring main for 3 bed house? How many sockets should it be use on on ring?
Dan
Dan
