Before I even start explaining the problem can I just say I've no idea about any "technical terms" regarding boilers so you will have to make any replies "Idiot Proof".
Basically I've got a Ferroli Modena 102 that won't fire up properly. If I use the reset switch the boiler will fire up for about 5 seconds and then cut out however the boiler shutdown light DOES NOT come on. Throughout the day the boiler may then keep firing up and then down but sometimes it stays on all day.
The main pain is the DHW. If the boiler is on the central heating is fine however as soon as I turn a hot water tap on the boiler will turn off and not fire up again.
The weird thing is that intermittently the boiler works perfectly. Last week both CH and DHW worked fine yet I haven't changed anything and now it is not working again...
Any ideas before I call out a engineer??
Thanks in advance...
