dodgy patio door
17 Apr 2006
Bournemouth
hi can anyone help we have just bought a house and have just found that to open the patio door you must lift the back end up and shuffle4 it backwards! does anyone know what the problem may be?
many thanks :D
could be numerous things
loose hinge especialy top !!!
when you lift the door is the frame tight !!
if the hinges are tight is there rub marks any where!!![between door and door or door and frame ect]
Is it a sliding or hinged one? If sliding, it might be there is a a dip on the rail that the wheels slide on, or maybe just some accumulated grit.
there may be a better way but I find it is necesary to wash the dirt out of the channel and rail, I use detergent and hot water in a watering can, and run the door back and forth to loosen the dirt, and keep pouring to wash it away.
