We have a couple of spot lights in the bedroom that were fitted about 5/6 years ago. They take GU10 lamps which never seemed to last long and after a couple of replacements we gave up and they haven't been used for several years.
Last night I fitted an compatible 240V LED lamp into the fitting and was shocked to find that with the switch in the off postion the lamp was illuminated, albeit very dimly!
It's not a residule charge in the lamp or anything, since they 'came on very dimly' the moment the lamp was inserted into the fitting.
When the electrician installed these spots, the main lights single gang switch was replaced with a new twin gang faceplate. None of the lights are on a two-way lighting circuit.
The only way I can see this happening is if the switch is dodgy. I guess they could be getting power from the unswtiched neutral and going to ground on the other side of the lamp at such a small level that the trip wouldn't go, but surely the moment I turn them on the live would follow the same route and throw the trip?
I like to think I have a pretty good understanding of wiring and the likes, but this has got me stumped!
Chris
Chris
