I managed to sort out a light that kept blowing, although the wiring is a bit unorthodox having obviously been done by a cowboy/DIYer. I know how 2 switches connected to 2 lights should be ideally wired but stuck with the wiring already in place. I just need to know that it won't blow again. I've made sure all wires are now screwed to their connections properly.
Here's how its wired:
Both black wires (usually used as the switch wire but not in this instance) are all connected to the neutral (blue) on the 1st light and the neutral from the 2nd light is connected to these black wires (all blacks together).
The common from one of the switches is connected to the 1st light and the red wire going from the 2nd light is connected up to these wires.
Both reds from the switches are connected to the other common.
It works but will it blow? I only made the best of a bad job as I couldn't be arsed to take up floorboards and rewire. Will I pay for my laziness or will this work fine even though its not done in the normal way?
