I want to put a greenhouse (aluminium, so lightweight) on top of an existing paving slab patio. As the slabs were not completely level & some were loose, I thought I'd re-lay it. The foundations are concrete (of varying height) from a previous building. I used the 5 spot method, and sand & cement. When finished it looked the business.
Next day I went to check, and noticed (from the edge and from the left over cement) that it wasn't solid. I thought I'd used a 1 in 5 mix, but I guess I measured it out inaccurately, or didn't mix it enough. Today (2 days later) its a little more solid, but I can still scratch a bit off with my nails.
So, what to do. Do I just relay the slabs which will take the greenhouse base and point it, giving it all a more solid edge around the sides (I'll use readymix next time)? Do I re-lay it all, yet again. Or do I leave it alone, as its fairly solid & as it is it is doesn't look like it will collapse. Could rain get into it, & freeze, & cause collapse.I don't know if the wet will causing freezing (there are a lot of gaps between the 5 blobs of mix).
My old dad was a builder, I wish he was here to ask. I'm an office worker (maybe thats why I'm now aching), but I always like to have a go. Thanks for any advice.
