I am fitting a video doorbell for a friend, what I thought was going to be a simple job turned out to be more complex as despite the chime box being 60 cm from the fuse box, it turns out the chime doesn’t contain a bell transformer at all and is in fact battery powered with C cell batteries.
Now, if I was able to break into a lighting circuit and take a spur off a light or a cable run, through a 3amp fused switch to the bell box and install a bell transformer, this would be in the DIY non-notifiable realm . However there is no access to any cabling from where the bell box is.
If I do the same by adding a spur from the output of a lighting circuit MCB in the fuse box (I.e. wire an additional cable into the MCB output, neutral and earth block) through a fused switch to the transformer, this is electrically the same thing, but is it now a notifiable change?
I can’t decide from reading the rules…
