- Joined
- 8 Jun 2017
- Messages
- 20
- Reaction score
- 0
- Country
I want to put underfloor heating in a small ensuite (just 3.5 sqm).
Having researched options (electric vs. wet), I found what seems like a good solution in using an RTL valve (return temperature limiter; https://www.floorheating-direct.co.uk/product/rtl-valve/). This solution just connects piping under the floor into the radiator flow and return, and limits the return temp preventing the floor from overheating. As I understand just like a lower temp radiator under the floor. Because it's a small area, it doesn't require a manifold or pump and runs on the existing system pressure.
Does anyone have any experience with this / what results did you get? I plan to use 12mm pipe on a preformed cement board overlay with channels for the pipe 150mm apart, tiling on top. I want to do this in 3 small areas in total (on separate valves and loops; 2 ensuits, galley kitchen, all under 3.5 sqm).
My system is a Combi Promax 28 HE Plus. I have 7 rads and 2 heated (wet) towel rails on this system; would it support this extra load?
