Hi all,
When burying armoured cable in the ground does it have to go in conduit? if it isn't in conduit will it corrode?
Mark
You can bury it direct in the ground, but you must ensure there are no stones near or in contact with it.
Thanks for the reply. Why can't it be near stones?
That is certainly what I'd expect and do...There's a specification somewhere for buried cables- short version, 50mm sand, cables/ducts, 50mm sand, marker tape, hard layer (I usually use bricks or bits of concrete, anything that will alert someone digging that there's something under there), marker tape, backfill.
No requirement whatsoever to use conduit or ducting.
But putting it in ducting could be extremely useful in the future, should the cable get damaged or needs replacing or alterations are made.
It 'filling with water' would be no problem - and certainly no worse than burying the SWA directly in (quite possibly sodden) soil.Not disagreeing with you but I do recall an electrician telling me that he doesn't like using ducting if there is a risk of it filling with water.
