I am re-plumbing the whole house using Hep2O manifolds and plastic barrier pipe, so a pipe run to each outlet (15mm & 10mm, as flow requirement dictates).
Most of the pipework will be in the loft, below the insulation. Should these pipes be lagged, as they should be the same temperature as the rooms below? Would there be a risk of very cold water entering the cold pipes causing condensation on the pipes, and damaging the plasterboard?
Any advice much appreciated!
