Does this cable have to be run in steel conduit in a notched floor joist?
If I cable Is running from one side of the room to the other and it is run through the centre of each joist all the way along, but when it comes to the end one, the joist is against the wall. To get the cable up the wall and behind the skirting board the last joist has to be notched out and the cable run in the notch to the wall then up behind the skirting board. If all the cable runs through the joists, but has to run through a notch right against the wall does it need to be run in earthed metal conduit just for the little run of a few 3cm?
I hope that makes sense and im sure it’s a very common problem.
