I know this is a bit of a 'how long is a piece of string' question, but I wonder if anyone could give an opinion on whether my kitchen floor is even enough to lay engineered wood boards onto, without my having to use a levelling compound.
As explained in a previous post (thanks to WoodYouLike for the responses he gave to that), the floor is concrete, and seems pretty level. I have chipped up any tile cement that remained from the ceramic tiles that I took up, and there is now just some slight 'ridging' from some softer substance, which I assume was the glue that held down the vinyl tiles that were under the ceramic! The stuff comes up ok, but it's gonna take a wile to scrape it off the whole floor, and I'd quite like to avoid having to do this or laying levelling compound - call me lazy!
I have taken some photos which are a little on the large side (apologies to those on dialup) but I hope they can illustrate the floor better than words. I should have swept up first really, as some of the bits you can see are just loose debris. Here's part of the floor:
Here's a close up of some of the slight unevenness:
There is one area where there is a dip in the floor, and I think it is due to there at one time being an internal brick wall. There is also a channel for a cable and this is the one part of the floor that I am planning to level up using compound. The spirit-level in this picture is set to dead level and shows the area that needs levelling:
I hope I don't sound like to much of an old granny, but I would like to have an idea whether I'm gonna hit problems laying a floating wood floor onto this. My best guess is that the the underlay/membrane will absorb the slight unevenness sufficiently well, as long as I level the area shown directly above.
thanks in advance for any help.
