does this need to be fixed urgently or it can wait a few months?
19 Jul 2024
Costa Rica
what happened here? is this important to be fixed? is it urgent?
Its a bent heat shield... hit something in the road. To be honest only you can tell if its rubbing, but you could just lay on the ground and bend it back so it doesn't rub.
Check to see if it has corroded around one of the bolts holding it in place.
If so, it can usually be repaired by using an oversize washer.
i will try push it back up to see if it secures better
