Does this plug striaght into a normal socket?
21 Nov 2005
Yorkshire
Siemens EH631BA68B Induction Hob
Plug type
GB plug
Type of 1st heating element
Induction heating, Standard zone
Dimension of 1st heating element (mm)
145 mm
Power of 1st heating element (kW)
1.4 kW
Type of 2nd heating element
Dimension of 2nd heating element (mm)
180 mm
Power of 2nd heating element (kW)
1.8 kW
Type of 3rd heating element
Induction heating
Dimension of 3rd heating element (mm)
145 mm
Power of 3rd heating element (kW)
1.4 kW
Type of 4th heating element
Induction heating
Dimension of 4th heating element (mm)
180 mm
Power of 4th heating element (kW)
1.8 kW
Power on indicator
No
Main on/off switch
Yes
Safety device
childproof lock, pan recognition, Power management function, Safety time-switch-off
Type of appliance width
60
Required niche size for installation (HxWxD)
51 x 560 x 500-490 mm
Width of the product (mm)
592 mm
Dimensions of the product (mm)
57.0 x 592 x 522 mm
Technical Properties
Energy input
Electric
Electrical connection rating (W)
2,990 W
Voltage (V)
220-240 V
Length electrical supply cord (m)
110.0 cm
It says that it comes fitted with a 'GB type' plug (i.e. 13A), and it says that the 'electrical connection rating' is 2990W (which is 13A at 230V, 12.5A at 240V) - hence not over the 13A rating of the plug, so I imagine the answer has got to be 'yes'.
Kind Regards, John
