View media item 87979
Just looking for a sanity check.....
We are having an extension built and need to remove the pre fab garage which has been built on paving slabs, and the concrete slab behind (in picture).
We have a quote for taking down the garage, removing the paving slabs (laid on earth) and digging up the concrete behind (75mm thick). The garage is sectional and bolted together.
There is a corrugated roof that may have an asbestos content, but the quote received assumes it DOES NOT (if the builder feels it does, then I will remove this myself and bury under the new extension).
I have taken down a similar garage 20 years ago (when I was fitter and younger) and it took me and a mate half a day using an angle grinder to cut through all the bolts and the apex angle iron roof frame, barrowed the sections to the front of the property, and I paid a 'guy with a van' to clear the panels for a £100.
The quote I have received is £3000 plus Vat (£3600).
Bearing mind there will already be a JCB digger on site (to dig foundations for extension) which he can use, and the site has access fro a grab lorry to clear the spoil, it seems quite high....
Or am I being unreasonable?
Cheers
Cheers
