- Joined
- 17 Nov 2005
- Messages
- 20
- Reaction score
- 0
- Country
here is the situation.
I live in a bungalow
fully pressurized system.
there are 14 Rads, 3 of which are towel rail rads
each room is on a separate zone, with it's own thermostat/timer
each zone is a separate drop of pipe from the main loop that runs through the loft.
After months of procastrinating BG have finally fixed my boiler by replacing a leaky heat exchanger. (Glowworm 30SXI)
this has fixed intermittent cutout and constantly dropping water pressure. The boiler now runs like a charm (touchwood)
My system is 3 years old and up until the boiler problems ran without a hitch for over 2 years.
My current problem is that my radiators are playing silly buggers,
some get hot and some don't (this can even be within the same zone) sometimes they are very very hot and sometimes lukewarm, there is no consistency basically take your pick as to which get warm on a given day.
What is consistent (most of the time) is that rads that don't get warm have their feed pipes roasting hot, and rads that get warmish are hot at the top and stone cold at the bottom. My hall Rad never gets warm, ever!
To my mind that sounds like sludge. BG are arguing not, as there shouldn't be a sludge build up in a 3 year old system. (BG didn't fit it by the way)
however my thinking is that
a) symptoms sound like sludge (radiators cold at the bottom)
b) I was topping the water up so often while they were attempting to fix the boiler (at least 4 months of at least once a day) that any inhibitor in the system has probably been diluted to the point of ineffectiveness.
So firstly do you think I'm right?
secondly if I get BG to do a powerflush (yes I know they are overpriced, but they then guarantee against blockages for life) should this solve the problem?
thirdly how long should a proper powerflush take? 14 rads and pipework sounds like an all day job to me. However my no-nothing BG engineer seems to think half a day sufficient?
all advice gratefully received as this is seriously winding me up now.
