Dog 'business' area - best coating?
6 Dec 2006
Dorset
Bit of a grim one this but in order to keep the lawn clean and the plants alive I'm going to be making a litter tray for my dog that I will sit round the side of the house on a tarmac area. Ideally the cheaper the better but I would like it to last and not
My current plan is to make a 1.2 x 1.4m tray from 18mm osb 3 that will be raised off the ground on runners (pressure treated etc), filled with gravel and drained via a 90 degree bulkhead and hose to the nearest drain.
I want to obviously coat the tray to protect it from wee, being hosed down and the elements but I'm not sure what to use a the moment - so far I've looked at the following (trying to keep costs under control:
http://www.wickes.co.uk/Wickes-Brush-Applied-Solvent-Free-Waterproofer-2-5L/p/164040
http://www.wickes.co.uk/Bostik-Flexacryl-Instant-Repair-for-Roofs-Grey-1kg/p/164204
http://www.screwfix.com/p/cementone...p-proofer-waterproofer-dries-black-5ltr/36405 - not sure this is OK as it says ideal for indoor use?
I've also looked at epoxy floor paints such as the no-nonsense one from Screwfix or the Leyland but I'm not sure they wouldn't crack and let moisture through without glass fibre reinforcement?
Anyway - anyone got any recommendations - ideally I want something that is going to dry (i.e. not sticky) but remains flexible and chemically resistant?
Check out cromapol or similar products. Much easier to apply than GRP. Doesn't set solid like GRP tho so that may or may not be what your after.
What's the point of a litter tray if you can train the dog to use the tarmac area?
Good luck with that, our dog is trained to go in one part of the garden only, but she still chases cats and birds through the flower beds, occasonally digs the grass and sunbathes in the flower beds.
He won't go on the tarmac area - he's been trained for years not to 'go' on paths etc. At our previous house we had an area enclosed with log roll and filled with gravel in a corner of the garden so we want to kind of replicate this but not actually in the main bit of the garden as the kids are 4yrs and 8 months respectively.
Yeah I'm not too precious about that - he is a spaniel after all so ploughing through undergrowth is just one of his things! I just want to keep the main garden free of waste.
How about getting one of those cement mixing trays from a builders merchant?
All ready to go then.
