I recently purchased an old house and it has a 3-phase supply (it is a semi-d, 90m2, with a overhead supply). It needs to be fully re-wired. My electrician notes that there is no need to use the 3-phases and recommended to just use one of the phases (and neutral) connected to a standard single phase consumer unit. Basically to then run the house from just that phase (which would include a 8kW heat pump).
The electrician noted this approach would be a lot simpler and cost a lot less (we are under significant budget pressure).
I don't see any major issue with this approach, would unbalanced loads be really an issue here?
