Hi There,
I'm currently installing a new built in single oven.
Currently From consumer unit to cooker switch above the kitchen worktops is 6mm cable on a 30amp breaker. Then from cooker switch with 6mm cable to a cooker outlet box underneath the work tops.
Now the oven came with a plug attached obviously this is now no use due to a cooker outlet point being there! Can I connect 2.5mm t+e from oven to straight to the cooker outlet ???
Any advice would be appreciated.
Whitt
Whitt
