First post on DIYnot and a bit of a tricky one at that.
Have just completed installation of a new kitchen in my own end-terrace property. I've completed the majority of the work myself (pat on back)but had a trusted friend offer to re-route the gas feed pipe (for free, not a tradesman) to existing boiler locating and new hob location.
And then I was informed about Gas Safe....
Yes its my own fault for not knowing the regs and rules I absolutely agree. It has left me annoyed with said friend as I later found out they knew perfectly well about the rules but didn't offer to inform me. I would have been more than happy to pay a registered engineer to do the work given how simple and easily accessible it was, and thankfully still is.
So my questions to you forumites are:
1) Given that only gas piping was re-routed (22mm down to 15mm copper through reduction coupler running a length of 5/6m in total from where it emerges from the solid floor with sweated joints (one t-joint, 3-4 elbows?) and a couple of compression joints), is there any certification required and if so, what is it called? The boiler itself was not modified in any way bar the connection the the existing 15mm copper gas feed.
2) If it is required, and I'm pretty sure it will be, who would be able and willing to test and certify the installation? The route of piping mentioned above is all still visible and accessible by hand for "bubble" testing and compression tightening of any joints.
I will say that for the friends lack of clarity, they have been fitting copper for gas/water for some 25 years, back in the day when this was perfomed by the DIYer (for better or worse). All to say that their joints are good, having soapy bubble tested and compression tightened all applicable joints myself.
3) What might this cost?
4) Is the local building authority notified following any certification? If so by who and what does that cost?
Thanks for your help in advance.
And no, I won't be letting said friend anywhere near my gas piping ever again...
