domestic hot water booster pumps
8 Mar 2009
Yorkshire
hi........ we have have just had a new kitchen fitted and the taps are the new continental type ( really low flow ). the hot water cylinder is in the loft so there is plenty of gravity flow. i have been thinking of fitting a domestic hot water booster pump. is this a complicated job ? or do i just fit the pump inline on the domestic hot water and connect the power to a suitable power supply ie: a fused 15amp socket.
cheers,
mickcoulson
You'll need to draw it off a Surrey or Essex Flange connection, depending on the manufacturers instructions, if you just try to fit it inline on your current system you'll get terrible trouble with it drawing air in all the time. They don't actually draw a huge amount of power, and are normally powered through a standard mains plug in a socket.
This could suit your needs http://www.plumb-warehouse.co.uk/ishop/968/shopscr1298.html
If you go for a Salamander, use their own S Flange, as doing so increases the manufacturers warranty to three years http://www.bellabathrooms.co.uk/prod-salamander_s_flange.html
The flange just screws into the top of your cylinder where the hot water distribution/open vent connection is
Wouldn't it be easier to change your kitchen mixer tap for one designed for low pressure?
