Vokera Linea Plus AG Combi
For years the DHW thermostat on the boiler was set for a water temp of 50C (on the boiler display) when a tap or our Mira Excel shower valve was fully open. This temp can no longer be achieved, summer or winter, regardless of thermostat setting. Typically, right now, it will get to a max of around 41C. Higher temp can only be achieved by restricting the flow at a tap (restricting the shower valve doesn't seem to have so much effect unless severely gagged to an almost unusable flow).
Boiler serviced annually, CH seems side ok, softish water area, whole system chemically cleaned this year and filter fitted, then heat exchanger removed, visually checked and flushed - all made no difference.
Two heating companies don't know what's wrong.
Hope this gives enough info and makes sense.
Any thoughts or ideas?
Many thanks in advance!
