domestic hot water
8 Mar 2009
Yorkshire
hi..............can any body point me in the right direction
the hot water tap on my bathroom washbasin keeps slowing down to a trickle.the other taps and shower are ok. i backflush the system from the cold tap in the kitchen and the tap will be ok for about a week then suddenly the flow drops again.
cheers
mickcoulson
p.s th tap is a single lever quarter turn
HI
ITS A COMMON PROBLEM WITH MANY TAPS THE CENTER THREADED UNIT DROPS IN HOUSING UNIT,YOU NEED TO TAKE OFF AND REMOVE CENTER THREADED UNIT AND REPLACE SO WHEN TAP IS IN OFF POSITION THE THREADED UNIT SITS FLUSH IN HOUSING WITH NO THREADS SHOWING
GOOD LUCK
sounds like you may have some floating debris in the hot pipework. Next time it slows I`d have a look inside the tap - or take off the flexi pipe feeding it (if you have one) and see if there is a mouse skull :eek: Yes ,I really did find one once - it was in a bath tap tho`.OR it might even be the flexi closing up inside - Please tell me there are flexis connecting the taps ;)
