Hi all,
I would like to run a cold water supply into my garage to feed a kit washing sink and then onto an outside tap, the garage is attached to the house but has no form of heating.
As I work away from home for a few days at a time the thought of a burst pipe worries me so I am thinking of ways to prevent this such as,
1. isolating valve immediately where the supply enters the garage, cheap but easy to forget to isolate when going away, but would be fitting anyway for local isolation.
2. extra thick insulation, not sure this would work over a period of sustained cold temps.
3.combination of insulation with trace heating, does anyone have any advice on a domestic system that can simply be plugged into a domestic socket with automatic thermostatic control?
