Domus STF100-T Extractor Fan Overrun Timer Problem
6 Mar 2011
Glasgow
I've installed a Domus STF100-T extractor fan, which I bought as a like-for-like replacement for a broken Silavent GTF100-T. The fan has an overrun timer controlled by a jumper and 4 pins. It's supposed to be adjustable for 5, 15 and 30 minutes, but no matter which two pins I connect it runs for 30 minutes. Pins circled in photo. The fan is operated by the bathroom light switch, via a 3-pole isolation switch. So far Domus technical support haven't been able to resolve the problem, so I'm reaching out to you guys.
Oh you think that's the problem? Damn. Was an eBay purchase. Doubt I'll get my money back.
Private seller I think. Bought 2 of these.
I read in a related thread that the type of lighting can affect the timer, but I didn't understand the very technical explanation.
I've got the extractor timers working by switching off the power at the consumer unit before moving the jumper to different pins. I had only switched off using the isolator switch before. I've no idea why this would make a difference but it has.
Presumably your 'isolator' doesn't 'isolate'.
Speculative thinking, but looking at this side of the PCB, there is an ELV side - shown by slots in the PCB and the 25V caps.
A simple variable timer could use the jumper links to select the small cap for @5 mins, the large cap for @15 mins and combine the two for @30 min fan delay.
It possibly wouldn't take much capacitive coupling to maintain a charge on these small caps even with the isolator switched off?
My head hurts after reading this :eek:
All I can say is they are working as required. I switch the light on and the fan comes on, then it goes off 5 mins after I switch off the light. If I switch off the isolator then the fan goes off. I'm not concerned about it resuming operation when I switch it back on, unless this were due to some major wiring issues, which it's not.
