Apologies for what may seem like a simple question to those in the know!
I have just had a new Carpet fitted and suprise, suprise, the door is now unable to open / close without real force. So I am guessing the door needs to be planed.
However, When the door is open, it needs >10mm cut (planed) off the bottom. But when the door is closed, it doesn't need anything. So if I just cut 10mm off the botton of the door I will be left with a big gap when the door is closed?
Is there anyway around this?
Also, could I use a Jigsaw to cut the majority off then finish with a plane? I only have a hand plane, and the thought of planing 10mm worries me!
