L
longdogs
Hi
What is the correct way to join a solid wood floor (13mm thick) to a carpet via a door bar? Should the existing metal gripper be removed and replaced by an appropriate wooden bar or should the metal gripper stay in place and the new flat bar fitted over the top?
My guess is that the gripper should be removed but that means there would be no gripper holding the carpet across the door way.
Thank you[/b]
Thank you[/b]
