Hello,
I have a problem when trying to close my living room door. I'ts not that the door dosent fit or wont close but if you push the door to close it, not completely but, closed as so the catch touches the strike plate and then let go, the door springs back about 8 inches as if something is forcing it back open. This is only a problem becuase if you want to close the door properly it means you have to push it firmly into the frame and then let go of the handle without releasing the pressure on the door, otherwise the door just springs open again becuse it dosent catch in time.
When you push the door closed, when its still about 8 inches open, you can feel a very slight resistance change. I thought it might be paint on the hinges (and there was a lot of paint on them) so, i removed it all down to bare metal but it didnt help.
I cant see anything else that might be causing it, any ideas anyone?
Thanks in advance.
Thanks in advance.
