Any of you chaps used door entry kits before...
Just a bog standard 1 way kit, with telephone handset and electric lock release.
Are they difficult to install?
Are they compatible with easy-opened-door systems?
fraid not, you appear to be refering to a "mag lock" these require power to hold the door shut, no power, door is released, they are very common, it is a health and saftey issue.
that said there are two types of "yale type" door release;
fail safe which neds a voltage to keep the door locked
fail secure which needs a voltage to release the door
in the kits you usually get fail secure
the pic below is 2 mag locks and one plate that goes on the door
the pic below this is "normal" door release with yale lock
yes. but "fire people" prefer maglocks, with a manual door release, similar to the one below
it is wired in series with the maglock, and just breaks the supply.
you can adapt a maglcok to work with a door entry system, but you need a separate power supply for the maglock and a relay to interface with the door entry kit
Surely a door with a handle to open it from the inside would suffice as in your picture "normal door relase with yale lock". So, if the power fails the door can be opened manually from the inside.
