I was thinking of adding some wing stops to bring the render over 10mm or so past the interface between frame/add-on. Then after painting maybe run a bead of exterior sealant up each inside edge?
Does this sound right?
Also, is there a dedicated sealing type tape or strip that's I'm supposed to cover the frame/add-on joint with, before I bury it behind render?
Thank you.
