Eldest childs door frame suddenly split last night, probably swinging on it. Anyhows its quite a big split around the hinge ive had to remove the door. The actual frame leads up into the loft and is also part of the frame for a window light above his door. How best to fix this? I was thinking of cutting it at normal door frame height and fixing in a new piece of timber. Attach hinges and door to this. The remaining existing frame will be covered as I have plastered over window light to blend in with the wall.
Or is there an easier way?
