I'm planning on dot and dabbing 12.5 plasterboard to brick wall but the door frame doesn't stick out much and the brickwork varies in places near the door frame.
What I'm thinking of using is some strip wood and sticking it to the door frame, is that acceptable?
What I'm not sure of is where abouts do you stick it on the frame. The strip will be on the door opening side. do you go right to edge where the door hinges are or place it a few mill back?
What I don't want to happen is the door to be impeded with the strip and architrave
