One for @crank39 In the process of fixing my jammed UPVC multipoint locking system, I have just spotted another slight problem....
Inside one of the door handle, there is like a plastic frame, with four springs, which bear onto a metal part. The metal part has a square hole for the spindle. Idea is, the springs help force the handle back to horizontal, after it has been operated. The metal part has broken, and I wonder if just the broken metal part, or the entire plastic frame might be available as a replacement part, rather than buy and replace the entire gold door handle? Not solid gold of course, the solid gold ones are only on the front door
Failing that, I could maybe make a matching part, from a bit of steel.
