Door just dipped - what next
5 Dec 2005
Surrey
I'm sure this has been done to death, but I couldn't find anything specific to the issue I have.
I had a door dipped, with the intention of re-painting white. It was kill or cure.
Anyway, after it's been dipped the wood underneath is actually in good condition (it's an original 1930s 5-panel shaker door). Am now considering leaving it natural (e.g. oiling, etc).
The only thing is it's pretty dark and a lot of the grain has gone grey (possibly due to the stripping solution).
What next: will sanding it (which it needs anyway), get it back to looking a bit lighter?
Cheers,
Ben
In my opinion dipping destroy's the intergrity of a door I would expect it to fall apart over the next few years. An hour or two with a heat gun would have been just as effective and a lot cheaper.
You are definitely right. But - also a lot of faff, and considering some of the layers of paint probably contain lead, I wanted to keep it well away from the kids.
Rant:
I love diynot and refer to it all the time, but why is it becoming a place where people don't answer the question the OP originally asked but just take the righteous high ground and tell you from their ivory tower what you 'should have done'. It's not constructive and it does not answer the question.
Your comment would be fine along with a constructive answer. As it stands all it really says to me is 'I know better than you. ner ner ner ner ner'.
Sure, it may fall apart, but as I said it was kill or cure, so not too bothered really. It was worth a shot for £20. Better than poisoning the kids any day.
Rant over.
Anyway... back to the question....
So what's next.. do you think it just needs some time to dry out, will sanding lighten it, bleach it, etc?
Personally I've never had a stripped door fall apart, but quite a lot of the softer sapwood does get removed with the process and this makes the surface grain uneven.
So, a good sanding down will sort that, then its on with a preparation of you choice and colour, really.
Re hang the door straight away, and then wait a week or so before treating.
John :)
I've had a load of doors stripped and doors that were already in poor condition generally came out worse but a good solid door can usually take wet stripping.
A bit of sanding when they are totally dry and then 3 coats of Danish oil makes them come up great in my opinion.
my suggestion
was it soaked for days in a solution??
if so lay it flat on several batons for around 6 weeks to shrink
clamp the sides together to close the joints
drill a 8mm hole through the tenon [2 or 3 on larger tenons ]
glue and knock in a 40mm x8mm dowel cut fill and sand
Don't think so. They turned it around in a day or so, so it probably had a skinny dip in a hot caustic bath.
Thanks all for the suggestions. I will leave it to dry out first. Think it may be dark because it's still damp. Will give it a sand once dry and see how we go from there.
Thanks!
