door linign b4 plasterboarding
5 Nov 2006
Sheffield
Probably a daft question - if you have new studwork would you get the door lining for the internal doors fitted before plasterboarding?
Just need to know when I specify what I want from the builder.
Cheers
John
John
you don't necessarily need the door casing in before plasterboarding, but you do need them fitting before skimming.
for a standard 30" door and casing, the studs need to be set at 813mm (32") apart. this will allow a little leeway as the actual size of a standard moulded casing is 805mm.
