Door lining advice please :-(
2 Jun 2013
Kent
Thanks for reading my (first) post. I have recently had some building work done which included having a new doorway put in through to an adjacent room. This room is still to be decorated so my builder (jack) has not put the architrave on the outside of the frame in the room to be decorated.
It has been pointed out to us that the door frame lining is not wide enough to cover the wall entrance, so Jack has suggested putting an infill of trim on the lining.
My question is, is this standard practice or should he have bought a larger lining kit?
The kit we have is a 32 x 140 however having measured it we need a 150mm which I presume you can get??
I am not a builder or carpenter so can only take his advice but it seems to me he is trying to cut corners which I obviously do not want to do.
Hopefully I have explained the issue well enough, I have shown a couple of pictures to help.
Sid
The structural opening is just that, an opening. If the frame/lining is smaller, then it's just a case of packing out the sides with timber, and then plastering over (with mesh used too to avoid cracking)
But obviously, the final opening should suit your needs. If you need a larger opening, get a bigger lining. If it is just a lining with no door, then you can make one up. Otherwise, work to door sizes
Thanks for the reply woody. I don't think I explained the issue correctly, it isnt the actual opening size that is the problem - it is the depth of the wall. Since it is a 60's property with brick walls they are thicker than the door lining 140mm) so he is talking about adding more wood which will be visible when the door is open.
Hope that makes sense.
Buy a thicker lining.
Or buy a thinner one, or reduce the one you have, and return the plaster around on one side of the opening
Add-on pieces tend to look like a bodge
