Door lining floor to ceiling
1 Nov 2013
My existing door lining go from floor to ceiling and have borrowed light/fan lights above the door.
Can you buy these extra tall door lining s from anywhere? If not can i use a normal height one and then make up something for the windows? Any suggestions? Will it look a bit crap with the join?
In timber these are called 'Storey Height Door Frames' and generally available, or easily made up. In PVC, I fear they would have to be made to order...pinenot :)
if you cant find them off the peg,then just buy the correct size floor boards and make them up yourself.
Thanks chaps
I had no joy in finding any ready made ones.
I removed one of the door linings and it seems that the bottom part was joined to the top part with a dovetail joint i think. So i will probably do the same.
