we are converting our garage and will need to replace the door and lining (the original door + lining never fitted) however it appears the off the shelf linings are not wide enough.
On the assumption of 100mm thermalite, 12mm boards, dabs 10-20mm walls a little out and 3mm skim, making the wide between 150-160. Your B&Q etc only carry 132mm frames. what are the best options, make one, trawl internet for wider frames, or tack stripwood onto the 132 frame to pad out? Any thoughts?
