We're at the stage on our loft that we need to start fitting the door linings before the plasterboard goes on. I had originally thought that the chippies were doing this as I was under the impression that this was a first fix item, but they treat it as second fix, and they are not doing any second fix items.
Wall make up is 95mm C16 studwork, so with 12.5mm plasterboard and 3mm skim each side, I am at 126mm width. Door linings seems to be 120mm or 132mm wide [finished size].
Presumably 132mm linings are the way to go, and the plasterer would make up this difference at doorways so the skim coat finished flush with the lining so the architrave can easily be planted on?
This is probably a non issue, but not having done this before, thought it best to check
Thanks!
Thanks!
