i,m after new door linings for two rooms, current ones are 100mm with 50mm depth each side. The new linings i need are 133mm (allow for wall render/plaster. Can you get 50mm depth or do i need standard 32mm and pack each side?
Are you fitting new doors? What is your door opening? I’ve never seen a door lining kit 50mm thick so if you really need one your either going to have to make your own, bodge a standard kit or buy new doors to suit a standard door opening width.
