I'm looking for a lock with both a latch and a bolt, where an outside key and inside thumbturn will operate the bolt, but after retracting the bolt, a further turn will retract the latch.
this essentially means the lock would not require a handle on either side.
Most lock cases i see don't give a very good description of the action, or it is difficult to track down.
Is there a keyword i should be using or do most locks do this by default?
