Door opening. Size required for 1981mm x 838mm x 44mm door?
You buy the frame beforehand and build it in.
Ha. Cheers for the reply. I hadn't really thought it would work that way. I assumed there'd be a standard opening for each common door measurement.
Is it the same with windows? Buy windows, then build blockwork to fit?
