C
cabot
I have the same problem with my Wickes conservatory with the french doors.
One of the doors seems to have dropped on one side and is catching on the other.There doesn't seem to be any means of adjustment.How do i go about fixing this problem as i have an uneven gap at the top which lets in daylight? do i have to remove the door from the conservatory and start to remove the glazing beads, then re square it up or what. If so how easy are they to remove and what sort of tool should i use bearing in mind i don't want to damage the plastic glazing beads?
_____________________________
lynda, moderator
Please do not hijack posts (forum rule 20) your post has now been split
lynda, moderator
