I have a 6ft gate in my back garden wall, it opens onto a "B" road and there is a bus stop nearby, so a modest amount of foot traffic. It is a 44mm softwood LBF made for me by a local joiner, with 450mm hook and band hinges, and a BS deadlock, so I thought adequate.
Yesterday I was applying preservative, took the lock out while working, refitted it loosely (no screws and keep not fitted) overnight while drying off.
After dark I observed that someone had given it a good kick. Today I saw a big scuff in the fresh preservative, and a slight crack near the lock. Where the thick metal faceplate of the lock is rebated into the door edge, the lip around the rebate has a partial crack or split.
The lock is 1/3rd from the top, and the scuff is near the bottom. I have fitted a padbolt near the bottom to reduce movement and take some of the load if it is kicked again.
I have a Kickstop steel plate reinforcer I can bolt over the lock, and am thinking of putting mortice rackbolts near the top and bottom.
What else can I do? I will assume it is some local ne'erdowell trying his luck, perhaps hoping I had left tools around.
