what I would like to do is to swap a door and a window around
I have a utility room with the back door leading off and the kitchen with just a window so it will involve taking out the kitchen window and removing the section of wall below leaving the lintel in place then having a door and window section made up to fit.
Then removing the existing back door from the utility room bricking up the bottom section and fitting a window to fit the opening .
So I'm assuming the lintels will both be ok
Is it ok just to remove the lower section of brickwork ?
Brick up the lower half of the doorway ?
Do I need building controll ?
The kitchen will remain the same and the utility room will then be used as a downstairs bedroom so apart from moving a couple of water pipes from under the window no other services / electrics need to be touched
Advice needed please
