Door weathering threshold beneath existing alloy cill?
16 Oct 2004
Hi.
Doors I am ordering (timber laminated/insulated from Russell Timbertech), have a narrow alloy "stormguard" as they call it cill. They will be mounted at DPC level - which is flush with internal FFL. The alloy cill ptovided is not wide enough to reach over the edge of the brickwork. I don't want to add a futher big thick hardwood cill which would either add a high threshold or require me to lower the DPC. I have currently specified the complete frame height as builders opening -15mm, so I don't have too much spare height to play with.
So what is the normal way of dealing with this and weathering in the door? I'd say that I possibly could do with an alloy folded section (or something) like shown below, but I can't find any ready-made solutions.
This really can't be so unusual - can it? So what does one normally do about this? - short of adding a thick hardwood cill?
I doubt very much there is anything on the market to do what you suggest, what i would do is go to you local steel stockholders and get a bit of brushed stainless cut to the width of your opening, im sure they'd be able to put the two folds in too
Yep, it seems like this is probably the way to go. I'll find a friendly metal folder.
It's surprising that a door manufacturer (who drew a bit of a blank themselves at this) makes a product which seemingly can't be fitted into a normal opening with any standard off the shelf stuff.
