Just bought a house...it's nice enough. However, Previous owner had:
a) A nailgun fetish
b) A lack of common sense sometimes.
All doors are quite new..stained to look older. ALL are warped, bowing in the middle. Some catch on the top of their frames, some catch on the back creaking and cracking. Most spring open unless firmly latched.
The strip that sits round the doors that they close onto in the bathroom in particular has a dog-leg bend in the bottom, so the bathroom door is a sod to close.
All the doorhandles are round, too close to the frames (fingers!), and bind/stick badly...the latches rarely pop back out. Some of the striker plates need moving as well.
Now, here's where I need advice from the good people on here..what tools would be most effective/needed to resolve these issues?
I'd guess at:
Sandpaper
Wood plane
Small chisel
to sort the frames out and give the doors some closure..
But what on earth can I do about sticky latches? I've tried WD40 - no go. Doorhandles came off the bathroom last night - stiff to turn, so I greased them...better, but not good enough..
The bathroom "vacant/engaged" lock was jammed solid..took it off, greased it..nothing. Looked at the rear section, realised it was screwed to the door so tightly (or possibly wrongly installed) that the moving disc was pinned in place. Sigh.
And lets not mention the wood trim that's been nailgunned to the doorframes...argh..or the shelves nailgunned to the wall...
a) A nailgun fetish
I'd guess at:
Sandpaper
Wood plane
Small chisel
