Doorstep Tiling Help !!
1 Aug 2009
Glasgow
Ive got a concrete doorstep I want to tile (about 2m sq)
Im planning on using common garden 15cm x 15cm red/brown quarry style tiles.
I need advice on adhesive, grout (grey), adhesive grout? and any other tips etc
Ta
Hi
You'll just need to use a flexible adhesive, I'd recommend the Ultra Pro-Flex Powder Adhesive. When you apply it, use a thick base layer. Don't use the dot-and-drab method.
You can use regular grout however be sure to use a tile sealant to protect against the weather.
Hope this helps.
